erogier
My phone has been working great since the previous issue....until today !
I bought a new 32 gb sd card since the one I was using was only 8gb. After I installed it , the phone started to boot loop. I removed the card and it booted up fine. Sooo, I reinserted the old card. Boot loop again ! So I removed the card and the phone still boot looped. I can boot into twerp, but that is all .Phone is rooted . Any suggestions ?
This is a Virgin Mobile Lg Volt (ls740). I made a back up and then did a reset wipe through twerp. Phone booted, but no service. Tried restoring the backup, booted , started upgrading apps . As soon as it finished it shut down and went back into bootloop. Wiped again, booted, still no service. Checked status in settings, no phone number or anything else ! Checked software and baseband unknown. I am not sure where to go from here. Should I reinstall the os per the unbrick guide as I did previously......?
Today at 2:42 AM
I bought a new 32 gb sd card since the one I was using was only 8gb. After I installed it , the phone started to boot loop. I removed the card and it booted up fine. Sooo, I reinserted the old card. Boot loop again ! So I removed the card and the phone still boot looped. I can boot into twerp, but that is all .Phone is rooted . Any suggestions ?This is a Virgin Mobile Lg Volt (ls740). I made a back up and then did a reset wipe through twerp. Phone booted, but no service. Tried restoring the backup, booted , started upgrading apps . As soon as it finished it shut down and went back into bootloop. Wiped again, booted, still no service. Checked status in settings, no phone number or anything else ! Checked software and baseband unknown. I am not sure where to go from here. Should I reinstall the os per the unbrick guide as I did previously......?
Today at 2:42 AM
