LG World & Fonts for stock
Bichofelix
I have found lgworld works for our device. It can be found here.
It can mainly be used for additional fonts.
Or if you want to skip the bs I made a backup from titanium that will install 100+ different lgworld fonts via flashing with twrp.
Code:
It unfortunately installs tb on your device, & idk if thats what you want.
May also downgrade your current tb.
Boost Mobile and want to do neither of these? Just install each apk manually from the zip.
Have fun :)
Code:
Have fun :)
How did you made it works its set SDK19?
It works. Flashed it to make sure. It installed titanium backup though :(
yes i understand that the zip will flash fine getting rid of TB no problem @ all I knw how to clean the house.. now the LG.world its skd19 kitkat 4.4.x... how you got it to work?
Install it and it will update itself on launch Want me to pull the updated one instead? Sorry, I misunderstood.
Yes please... I had the apk when i had the f6... I installed it here didn't work... Then i saw u said it works but i have same sdk. Its not pushing or pulling updated one...
This is my issue.. I have put it in system apps n in priv.apps this its what i get
