Hey guys
First post here and I'd like to say I'm a complete beginner at android development (got a lot of programming experience though)
I was going through Google's own 'Dev Guide' looking at LinearLayouts and started playing with the "android:layout_weight" property when I noticed something odd. Heres my main.xml
If I increase the "android:layout_weight" property on the TextView objects (is this what you call them? ), they expand and push the others accordingly as I would expect, however it seemed to be the total opposite when I increased the weights of the LinearLayout objects. The increased LinearLayout got smaller and was pushed by the other(s). Is this behaviour working as intended or do I have something mixed up?
This I know will have a ridiculously simple answer, but I gotta start somewhere
Thanks in advance.
PHP:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<LinearLayout
android:orientation="horizontal"
android:layout_weight="1"
<TextView
android:background="#aa0000"
android:layout_width="wrap_content"
<TextView
android:background="#00aa00"
</LinearLayout>
<LinearLayout
<TextView
android:layout_height="wrap_content"
<TextView
android:background="#FFFFFF"
</LinearLayout>
</LinearLayout>
Thanks in advance.
