Apps List<Map<String, Object>> problem
yysiow
My XML file have 11 record, when i use List<Map<String, Object>> to add the data, the last record become first record.why?? any one can help..
below i give some example..
Map<String, Object> item;
final List<Map<String, Object>> data = new ArrayList<Map<String, Object>>();
for(int subicount = 0; subicount < subgroupList.getLength(); subicount++){ //subgroupList.getLength() is 11.
item = new HashMap<String, Object>();
item.put(ITEM_ICON, bitmap);
item.put(ITEM_TEXT, ((Node) subname.item(0)).getNodeValue());
data.add(item);
date is "A,B,C,D,E,F,G,H,I,J,K".
but in the listview result is
result is "A,B,C,D,E,F,G,H,I,J,A".
I can sure when i do the loop, the last record is K. but put in list view become A,
any ideal on it. please help. thanks.
yys
