ListView problem. Cursor gets closed.
mlgch1
I am using ListView to display a small list. I know it's on the main thread, but this is not a problem. It used to run under earlier API levels but gives a problem under 27.
Code:
package com.scorer.tennis;
import android.app.Activity;
import android.database.Cursor;
import android.os.Bundle;
import android.view.View;
import android.widget.ListView;
import android.widget.SimpleCursorAdapter;
public class LogActivity extends Activity {
    DBAdapter myDb;
    @Override
        setContentView(R.layout.activity_log);
        myDb = new DBAdapter(this);
        myDb.open();
        populateListViewFromDB();
    @Override
    protected void onDestroy() {
        super.onDestroy();
        myDb.close();
    public void Clear_Log(View view) {
        myDb.Clear_Log();
        finish();
    private void populateListViewFromDB() {
        Cursor cursor = myDb.getAllLogRows();
        // Allow activity to manage lifetime of the cursor.
        // DEPRECATED! Runs on the UI thread, OK for small/short queries.
        startManagingCursor(cursor);
        // Setup mapping from cursor to view fields:
        String[] fromFieldNames = new String[]{DBAdapter.KEY_LOG_ID, DBAdapter.KEY_LOG_DATE, DBAdapter.KEY_LOG_TIME, DBAdapter.KEY_LOG_LOG};
        int[] toViewIDs = new int[]{R.id.item_id, R.id.item_date, R.id.item_time, R.id.item_log};
        // Create adapter to many columns of the DB onto elements in the UI.
        SimpleCursorAdapter myCursorAdapter = new SimpleCursorAdapter(this,     // Context
                R.layout.log_item_layout,                                               // Row layout template
                cursor,        // cursor (set of DB records to map)
                fromFieldNames,                                                         // DB Column names
                toViewIDs);                                                             // View IDs to put information in
        // Set the adapter for the list view
        ListView myList = (ListView) findViewById(R.id.id_log_list);
        myList.setAdapter(myCursorAdapter);
On executing the last line (myList.setAdaper...) it bombs out with:
Code:
W/Adreno-EGL: <qeglDrvAPI_eglGetConfigAttrib:612>: EGL_BAD_ATTRIBUTE
D/vndksupport: Loading /vendor/lib/hw/gralloc.msm8937.so from current namespace instead of sphal namespace.
D/OpenGLRenderer: eglCreateWindowSurface = 0x8c06fe68, 0x8b5ce008
D/ViewRootImpl@a5eda92[OtherActivity]: MSG_RESIZED_REPORT: frame=Rect(456, 32 - 823, 799) ci=Rect(0, 0 - 0, 0) vi=Rect(0, 0 - 0, 0) or=2
D/ViewRootImpl@a5eda92[OtherActivity]: MSG_WINDOW_FOCUS_CHANGED 1
V/InputMethodManager: Starting input: tba=android.view.inputmethod.EditorInfo@8c0dde nm : com.scorer.tennis ic=null
D/InputMethodManager: startInputInner - Id : 0
I/InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
D/InputTransport: Input channel constructed: fd=74
D/InputTransport: Input channel destroyed: fd=72
D/ViewRootImpl@a5eda92[OtherActivity]: ViewPostIme pointer 0
D/ViewRootImpl@a5eda92[OtherActivity]: ViewPostIme pointer 1
D/ViewRootImpl@a5eda92[OtherActivity]: MSG_WINDOW_FOCUS_CHANGED 0
D/InputTransport: Input channel constructed: fd=75
D/ViewRootImpl@a934784[LogActivity]: setView = DecorView@497db6d[LogActivity] TM=true MM=false
D/ViewRootImpl@a934784[LogActivity]: dispatchAttachedToWindow
D/AndroidRuntime: Shutting down VM
    --------- beginning of crash
E/AndroidRuntime: FATAL EXCEPTION: main
    Process: com.scorer.tennis, PID: 1109
    android.database.StaleDataException: Attempting to access a closed CursorWindow.Most probable cause: cursor is deactivated prior to calling this method.
        at android.database.AbstractWindowedCursor.checkPosition(AbstractWindowedCursor.java:139)
        at android.database.AbstractWindowedCursor.getString(AbstractWindowedCursor.java:50)
        at android.widget.SimpleCursorAdapter.bindView(SimpleCursorAdapter.java:150)
        at android.widget.CursorAdapter.getView(CursorAdapter.java:289)
        at android.widget.AbsListView.obtainView(AbsListView.java:3180)
        at android.widget.ListView.measureHeightOfChildren(ListView.java:1448)
        at android.widget.ListView.onMeasure(ListView.java:1355)
        at android.view.View.measure(View.java:23407)
        at android.widget.RelativeLayout.measureChildHorizontal(RelativeLayout.java:715)
        at android.widget.RelativeLayout.onMeasure(RelativeLayout.java:461)
        at android.view.ViewGroup.measureChildWithMargins(ViewGroup.java:6967)
        at android.widget.FrameLayout.onMeasure(FrameLayout.java:185)
        at android.widget.LinearLayout.measureChildBeforeLayout(LinearLayout.java:1514)
        at android.widget.LinearLayout.measureVertical(LinearLayout.java:806)
        at android.widget.LinearLayout.onMeasure(LinearLayout.java:685)
        at com.android.internal.policy.DecorView.onMeasure(DecorView.java:909)
        at android.view.ViewRootImpl.performMeasure(ViewRootImpl.java:2952)
        at android.view.ViewRootImpl.measureHierarchy(ViewRootImpl.java:1950)
        at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2236)
        at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1843)
        at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7978)
        at android.view.Choreographer$CallbackRecord.run(Choreographer.java:911)
        at android.view.Choreographer.doCallbacks(Choreographer.java:723)
        at android.view.Choreographer.doFrame(Choreographer.java:658)
        at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:897)
        at android.os.Handler.handleCallback(Handler.java:790)
        at android.os.Handler.dispatchMessage(Handler.java:99)
        at android.os.Looper.loop(Looper.java:164)
        at android.app.ActivityThread.main(ActivityThread.java:7000)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:441)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1408)
Can anyone please tell me what is happening to the cursor?
