Lite Launcher - Super lightweight and smooth interface for Android
Bayberw
With the motto to help the phone use the interface in a minimalist, smooth and not be bothered by ads or lag. Lite Launcher is a small but powerful interface customization application with all the basic features you need. It can help users find the most used features on their phones to provide continuous adaptive reception services depending on usage.
Features:
  • Start searching for anything, Apps, contacts, settings,...
  • Always see your history, for fast access
  • Add tags to search results
  • Access to most used apps
  • Learns from your habits
  • Quick access to create Call, SMS for a specific contact
  • Change colors bar, primary color…
  • Show newly installed apps in history
  • Show favorites above search bar
  • Show weather
  • Exclude favorites from history
  • Hide favorites bar
  • Hide navigation bar and turn on immersive mode
  • Hide status bar
  • Web search
  • Restart Lite Launcher, for fixing any problems
  • Exclude any apps you do not wanted from Lite Launcher
Lite Launcher allow users to save time and battery power.
Lite Launcher becomes smarter and smarter as you use it, pushing forward results you're more likely to select.
If you like, please rate Lite Launcher. Thanks for helping us making Lite Launcher better and better for all users!
Link download:
DOWNLOAD LITE LAUNCHER
