Local and global sound control
JohnSpo
I've been on my Razr for about a year now after upgrading from my DX. I've found several features missing from the Razr that were in the X that I would like to get back.
The most annoying is the sound controls.
I use my phone extensively in the car dock for music, navigation and hands free calling. I have a USA spec interface in my truck so that the phone's audio comes through my truck stereo.
With the X I was able to set the volume for each running app individually and then use the master volume to raise or lower all at once. In this way I could set the volume of my music to a comfortable listening level and the voice nav to a higher level so that I would hear directions clearly.
On the razr not only am I unable to adjust sound individually but the music level is substantially lower than the nav voice.
Once I get the music at a decent listening level the nav will blow your eardrums out when it comes on.
I've looked at every setting and numerous apps but have been unable to fix this. Can anyone help with this?
