bburgdroid
Using these 2 apps on an Eris with 2.1
After I unlock using LBPro, the BW home widget (weather - rain, sun etc.) are not engaged. If anyone is using these 2 together please advise of what settings you use.
I am using LauncherPro Plus but if I turn off LockBot Pro the BW animations work so I know it's not Launcher Pro Plus that is causing the conflict.
Thx
bburgdroid
Thx
bburgdroid
