Lock Screen Problems
As can be seen from the image, after an upgrade to EMUI 5.1.0 the lock screen ,after entering my password there is no way to click on to enter it. All other phones have an arrow or something to click on. So ATM my phone and sim are useless. Any help would be appreciated as I do like the phone.
Maybe you are having the same problem others discussed yesterday about it related to screen filter and so on..try to find it down below..
I hope that helps..
Let us know.
Have you tried to scroll up on the screen to see if the enter or check mark is off the screen at the bottom?
