Hi
I installed the system software update last night for my S3 and since then the wallpaper for my lock screen has reverted to the standard dandilion picture. I tried to set it as I had it before but its has not worked.
Did you do the samsung firmware/os update thru Kies OR is your phone rooted?
On the stock phone you could select any picture -> invoke context menu -> Set picture as -> wallpaper.
On the stock phone there's no way to remove the wallpaper. The workaround to getting rid of wallpaper is to take a 100% dark picture and set that as your wallpaper.
Hi
The update just appeared for download and install.
I have tried the various standard ways to change the lockscr wall paper ( as I had done this successfully before ), but the new wall paper does not appear after I press "save" in gallery
