Lock Screen Weather Widget Help
wwu11
Trying to get the weather widget on my lock screen for my note 5. I currently use the Transparent weather widget by Machapp. When I go to lockscreen setting to turn on the weather for lockscreen under "show information" it says I need the Samsung Weather widget on my home screen. Now i have no idea what the samsung weather widget is since i cant find it in the play store. Anyone have any ideas?
[QUOTE=" Now i have no idea what the samsung weather widget is since i cant find it in the play store. Anyone have any ideas?[/QUOTE]
Press on your home screen or squeeze the screen so you can see the choices at the bottom: Wallpapers, Widgets, Themes, Screen Grid. Select Widgets. Scroll through the pages until you see the Weather 4x1 widget with the clock and drag it onto your home screen. Then press on the home screen again to go to full screen.
Hope this helps.
I figured it out incase others have same issue. I was using Nova Launcher and the stock Samsung weather widget doesnt work with that. I had to go back to TouchWiz, Put the stock weather widget on home screen, turn on weather in the lock screen settings then go back to Nova Launcher.
