Help Locked out/Pattern Need Factory Reset
Ok first off.. I cannot believe this tablet has hardly any information regarding system restoring/system factory reset. I keep getting mislead information on how to get to the system factory restore screen. From what I am gathering now, I need to hook it up to a computer to actually access this tablet to restore it to factory.
Here is the scenario:
I bought a used tablet from an individual that was feed up with it because her daughter locked them out of the tablet. Well.. after much failure at guessing this 7 year old's secret pattern, I felt it was time for a system restore.... well... this is where I need help. I cannot find any documentation describing this process or how to go about it. I have tried the volume + and - with power process several times, can only get to a solid black screen with two led lights on.
I understand this is where usb debugging comes into play, however you have to have this option turned on for this to work right? I have no idea if that's the case for I have never been able to get into the system. I have ordered a usb cable for this tablet.. hoping I'm not barking up a tree for wasted money.
Any help would be appreciated.
Yeah, I was hoping that method was going to hit it on the nail, since it was detailed specifically for the K1. I opened the back of the K1 and unplugged the cable... i'm assuming that's all I have to do correct? Then tried the push button method but could never get the screen to pop up accordingly.
Hi
I dont have your tablet to test it but are you holding the vol button until the screen in No4 appears? I think thats what it needs. (ie continue holding after you have released the power button)
Roger
