Lockscreen and home screen personal Info
DonB
♡ Truth, Justice and the American Way !! ♡ ™
Moderator
Nov 30, 2009
20,582
10,597
18th Hole Of the Golf Course
I am using the AVG security, but I really don't need it, the only reason why I keep it is because I have my info on the lock screen home screen incase I loose my phone, are there any apps that do that without having to use AVG, I know I have seen them before can't remember the name of them.
OK I set t up with my contact info, but how do you get it to show up on the lockscreen, I will reboot in the meantime incase, thanks again
No problems on stock G1, Magic or N1.
Note that I don't put a lot of information in - just a name, number and email address from my contact card.
Also note that it's important to clear the info out before uninstalling it.
Upvote 0
BEST TECH IN 2023
Smartphones
