Longer Mains Charger
Chris1710
Considering the Micro USB cable that comes with the device is relatively short in length when using it for mains charging, i was wondering if you can use any USB to Micro USB cable, or is there a set of specific specifications that i need to look for when getting a longer version?
I am in the UK for those who may post links to products...
Cheers in advance
You should be fine with any USB to microUSB cable. Just don't try two join to cables in one to make them longer, otherwise the charging will be utterly slow.
If you are just using it to charge, I don't think there is a difference between USB 2.0 and 3.0. Correct me if I am wrong...
