Looking for a screen protector for Nexus 7
markw10
I just ordered a Nexus 7 which will come later this week and want opinions on screen protectors. Should I get a screen protector or are they necessary for a Nexus 7?
If I end up ordering a screen protector I'm obviously looking for one that does a good job protecting the screen but also I'd like one that is anti-glare since I will use this at times in bright environments. Also the ability to prevent fingerprints/smudges would be great also.
Thanks for your advice.
I think to buy a screen protector for Nexus 7, It can better protect our Nexus 7 screen to avoid scratches, dirty.I buy this Matte screen protector for Nexus on tinydeal ,i feel good, you can consider it.
of course. badly needed.
For what it does, the value of the Screen Protector with Cleaning Cloth Samsung Google Nexus S is incredible. Buy more than one.
My initial impressions of the quality of the screen protector were very good, and similar to other screen protectors that I have used for long periods in the past.
The screen protector fit perfectly on Samsung Google Nexus S.
