Looking for a speed dial recommendations
NQuateman
Member
I have an Evo, and I will be using Touchdown for email, contact, and calendar. I'm wondering if anyone can recommend a speed dial app with the following features.
1. Avoid having to use numbers to identify or select a speed dial entry.
2. Small icons on a home page in order to fit as many as possible on the screen.
3. The ability to include complex dialing such as pauses, *, and #.
An example of a promising applicatioin is My Pals. But, I can't tell if it can dial with pauses and characters.
Thanks.
