A
Android Question
Guest
Hello!
I bought a new mobile (kingelton g9000) , it's chinese copy (clon) of the Samsung S5.
Everything runs smoothly, the only problem I have had was with loosing a signal.
It showed a message that "the card is not in slot" but it was there. Then it disappeared , but if
someone called me, I could have not answered because I had "no signal" but the message about the
missed call didn't come either , what is a little bit strange.
I have bought a new SIM card (micro SIM) and now it doesn't show the message about the missing Sim,
but mostly , when the mobile is in "standby" , you can't call it , cause it doesn't have a signal.
It doesn't do it always , only somethimes, but it's quite frustrating, because a don't now if some called me or not.
Thanks a lot for comments and solutions,
Peter
Peter
