Loss of network signal / No internet connection possible / Simcard detection error
Stocca
Samsung Galaxy J3 DUOS (2016)
SM J320F/DSGSMH
SAME IDENTICAL PROBLEMS IN TWO DEVICES (one is mine, one belongs to my wife).
Black: bought 16 April 2016
White: bought 14 May 2016
For both phones holds true:
Phone is encrypted (phone+microSD card) and updated the latest android version.
Simcard/provider: vodafone.de
Simcards are quite new (we got an updated "micro" version to fit the new phone slots)
There is a microSD card (64 and 128 GB) and a 2nd SIM (lebara.de).
Errors:
1) Loss of network signal (with battery drain sometimes)
2) Loss of signal when activating internet connection / No internet connection possible
3) Sometimes: Simcard detection error ("Please insert simcard" message)
See screenshots
Tried solutions:
- Removed the SIM card and cleaned the SIM-tray with compressed air. Re-inserted the SIM.
- Added a small piece of paper to push better the simcard to the contacts in the slot
- Swapped positions between SIM1 slot and SIM2 slot
- Selected "3G only" and not "LTE/3G/2G(auto connect)" in network connection options
- Network operators: swapped from "automatically connect" to a manual connect on vodafone.de
- Wiped Cache Partition after soft reboot
Nothing worked, the problem reappears from time to time.
The only thing that works after "Simcard detection error" or Loss of network signal is rebooting the phone.
Our SIM Cards work well on another device (Huawei G525).
I think it could be a software issue. It is difficult to believe that we have a hardware issue on two different mobile phones...
Any suggestion?
Thanks
