Help Low on Memory! What to do? N1
dkonkin
My N1, except for running out of RAM/memory, continues to prove itself against the iPhone 4S (for my use any ways).
What avenue do I take to Optimize RAM/memory? I have put all the apps I can onto the SD card. Some I can not move (original unaltered N1)
1. Is there a APP that will delete any crud left over from deleting other apps that takes space?
2. Is ROOTING the way to go?
3. Unlocking the boot loader?
4. Other options.
I looked at one set of instructions to root but it said WINDOWS only! What happens if I am using a MacBook Pro.
Any insight is very much appreciated.
Thx
David
