Machefaccio
good evening, I hope someone can help me with the issue I'm having on my M8 android tv box using a samsung tv. Whenever I run xbmc the hdmi connection between the tv and the box is lost after about 20-30. This only happens when I am running xbmc not when running say showbox or streaming a film from my hard drive, only with using xbmc.
I've tried different hdmi leads, using different ports and I've actually had this same problem with two different M8 boxes.
Is there an incompatibility issue between Samsung TVs and the M8 boxes? Has anyone else experience this and if so, have you found or know of a solution as it's very annoying that I can't watch anything on xbmc for more than 20-30 before the connection is lost.
The blue triangle light stays on but the tv reports that there is not a device connects to the hdmi port so I have to unplug the m8 and plug it back in for the tv to register it.
Thanks for all your help.
Gee
Gee
