Help M8-T8 Android XBMC TV Box‏ Problem
I have a playgadgets T8 -M8 android tv box and i want to know if anyone else as got 1 of theses boxes so that someone can check somethink for me
Today on xbmc and kodi i went into the 2 apps and under the movies tab i tryed a few things out what were
1st i tryed cinema movies and when i tryed that it came up with - script failed xmovies 8
2nd i tryed online movies pro and choosed recently added and it said - script failed online movies pro
3rd i tryed icefilms choosed movies then HD 720P then highly rated and that said - an error had occured communicating with icefilms check your internet connection and the icefilms site
About 2 weeks ago i factory reset the box and then went into your playgadgets app and downloaded and installed all of the xbmc addons and then once i had finished that i opened xbmc and let the program update once that had finished i then went to install the kodi addons under the playgadgets app and then them completed fine so i don't fancy reseting the box again because it takes a long time to do everythink again
so please can you someone try the same apps as me what i put above and let me know if you get the same thing as me
the company i got the box from are on ebay called playgadets and there website is playgadgets.co.uk
Thank you from Neil
