Root M835 driver issue
shain00
Member
Got a problem when i hook up my m835 to my computer, i used driver max to find all the missing drivers and now this happens, yes ive basically dont the unmounting and debugging and other stuff can anyone help.
Heres the Pic
Try installing these drivers. AscendUSBDrivers.zip They are actually for the Ascend M860. Nothing will happen if they dont work. I know the Ascend CWR works on the M835 and seen people say CM7 for the Ascend does too so my guess the drivers would be the same. Just download it extract it to your desktop open it and select "PCOptions" then select install usb drivers and when the config window goes away plug your phone in.
