This may have done the trick! I'll have to watch the battery drain to see if it's worth it.I'll have a look at this, thanks.
I added it to my post.Action = screen on
And in macrodroid big green wrench button, trigger options, proximity sensor = work with screen off.
I'm now playing around with the shake trigger versus the proximity sensor so it doesn't wake up the screen when I put the phone into my pocket.
Sure! I'd be interested. Post the configs.I have a flip case on my note 4 with 2 macros that turn the screen on when I open it, and off when I close it. Also it re-wakes the screen after timeout (with the case open) by waving over the prox. sensor. Without the case, it works fine (off in pockets, on out of pocket) too. I added some time delays so that accidental offs dont happen. I can send these to anyone who is interested..
I think the guy who wrote MacroDroid just about has to live in the loony bin by now![]()
I've been trying to use it in place of Llama to trigger off cell towers. It seems to identify them correctly (for my home and workplace) but falls to correctly trigger. Any recommendations?
So, how do you use location triggers without wasting battery? I'm using a Samsung Galaxy S7.
