fabler
MagicMarker is a simple and free paint program for android. You can create an art-work using neon lights.
It supports different colors of neon lights to draw art-work. It has a color chooser to choose neon color.
You can choose almost any color to draw. A plat is also provided with some pre-defined color to be choose from.
It also supports different thickness of neon lights to be drawn. There is an option to clear everything on canvas (basically a new canvas button).
Undo/Redo buttons are also provided. It also provides a eraser to erase some part or drawing. The art-work can be shared via MMS, you can set it as wallpaper also or save it on SD card.
You can import any wallpaper form your gallery and make a neon drawing on it and then share or save it. Here are some pros and cons of this application.
Pros:
Cons:
Screen1
Screen2
QR code
Pros:
Nice color chooser
Share via MMS
Set as desktop wallpaper of the phone
Import a picture from gallery.
It's feel very smooth while drawing.
Cons:
Multi-colored neon is not possible to draw. (one can draw neon with different color)
Multi-touch can be implemented for drawing.
Only round shape brush is provided to draw neon. Other shape of brushes can be provided.
Sharing via facebook/flickr/piccasa can be provided
Only black canvas color is supported. Canvas color cannot be changed.
Screen1
![qinE.u.cs.png](http://www.androlib.com/appscreenmax/qinE.u.cs.png)
Screen2
![qinF.u.cs.png](http://www.androlib.com/appscreenmax/qinF.u.cs.png)
QR code
