Manage Expenses with android application
laursxter
Hi there,
I make an android application that help you to manage expenses.
The name of the application is "Manage Expenses - Free" and download link is: https://play.google.com/store/apps/details?id=en.dcl.manageexpensesfree
The application allows the management of your expenses, as well as of the notifications for the future expenses:
- Add an expense
- Modify an expense
- Delete an expense
- Notifications in status bar
- Group by categories
- Reports
- Calculate total values
- Statistics per time periods
Data is saved on the local device and Internet connection is not needed while using the application. The application has a mechanism used to export data from the application and import it into other application which is installed on a different device.
