manual update now problems with contacts??
I followed the detailed instructions and manually updated my g1 to the 1.5 cupcake.
In the instructions I found on youtube it mentioned you may have to auto sync the contacts.
Alot of my contacts are no longer there after the update. When I try to auto sync the contacts I get this message,
"Sync is currently experiencing problems, It will be back shortly"
Any ideas on how to fix this?
