Market issues
Status
Not open for further replies.
wryun
I don't know if this is Virtuous, or the Market, so I will start here.
It seems like 50% of the time when I download an app from the Market, it downloads, but then gets stuck. It doesn't install. This happens with single apps now and then, but ALWAYS happens when I try to install/update more than one app at a time.
Anyone else?
Anyone else?
I have not run in to this issue on any Virtuous builds, with the exception of the Gmail 2.2.1 fix and trying to update to 2.3, but we knew why that happened.
Everything else has worked just fine.
I ran into this issue before on both stock and Virtuous 2.5. It went away when I flashed the 9.01 radio and then did *228. Not sure which one did the trick.
Happens to me sometimes as well. It's been happening with every Sense/Froyo build I've run since the first leak. Next time it happens to one of you guys, see if you can catch logcat output of why it is failing. Once we have that I'll have some idea of whether we can address this at all ourselves or need a fix upstream (from HTC or Google).
Status
