Marshmallow battery drain?
ckar
Hello- I'm noticing a pretty significant battery drain issue after updating to Marshmallow. In particular, I see "Media Server" as the biggest battery drain culprit when I go into the battery settings. What is this and why is it eating so much juice?? Thanks for any guidance.
hi.
I recall that app issue from my s3 days but can't remember the fix sorry...have you tried the factory reset action to see if that helps?
cheers
Dan
Or you could buy an S7, like they're trying to force you to...
