Murf1
I updated Boost version to android 6.0 from their push.
I have a 32GB SanDisk SD card. Looking in "Storage" the phone recognizes that only "3.52 GB used of 29.71 GB". Hooking phone to PC via USB cable Windows also recognizes the same results.
I was able to move a couple small apps to SD without issue with the normal built into Android method under Storage.
Now when I try to move any apps to SD the progress bar will get up to 90% and then I get the message "Not enough storage space". Really!?! I never had this issue on 5.1.1.
Anyone know what is causing this and how I can make it realize that there is indeed plenty of space on my SD card?
Thanks
Thanks
