Marshmallow wifi issue on Note 4
scanman
I got the upgrade to marshmallow the other day. I'm on sprint and the update hosed my wifi. I was reading through stuff on the Internet and it seems that if you go to...Settings -> Backup and Reset -> Reset Network settings, which resets all your Wi-Fi, Mobile Data and Bluetooth settings, the problem is resolved. I hope this bit of information helps someone.
Update to my issue - though it appeared that the problem was solved it still occurs, but if the steps I described above are followed you get wifi back. Unfortunately you have to sync your bluetooth devices and enter you wifi passwords.
you are so right, but in 5.1.1 it is just simply 'reset'
even if VZW releases 6.x for us, I think I am going to just skip it....
my daughter has a HTC M9 and on the forum, there is a lot of gripers who wish they had never allowed it to happen to their Verizon phones.
I asked her if she wanted to 'update her phone', she said no, so we told it "NO"
Ok, so I was still having the Wi-Fi issue and decided too take a chance on a hard reset. Good news, it solved my problem plus my battery life is phenomenal. Other people's results may vary. I'm not sure what the issue was but I am adding back only the apps that I use on a daily basis too see if it might have some the garbage I had downloaded from the play store. I'll keep you informed any other issues arise. Cheers.
...syncs now I'm back to square one. Thinking about the 7 edge because I can't wait for an update to fix the issue.
Well, the phone went from bad to worse. Another update was rolled out and that really messed up my phone. I dropped it off at the corporate sprint store a couple of hours ago. I will pick it up when I am done with work. It may or may not be fixed. Either way I think I am done with this phone and going to get the S7 Edge.
The phone was so fubar'd the sprint tech couldn't fix it. They offered a refurb unit but I would have had to wait a week or more. Went with the S7 Edge. Good bye note 4 community.
