Brian Davies
I have a power pack with two outlets: 2.1 amps and 2.4 amps. If I use the 2.4 amp outlet will it damage the S7?
The 2.4 amp port is preferable but the difference between the two is negligible. Basically it's not even a matter where your phone will be pulling in a full 2.4 amps the entire time it's charging anyway. It will peak early on and then the amount of current needed tapers off as it charges. Once it's close to 100 % it probably won't be taking in 100 mA or so.
