Help May someone help
I'm wondering why I have 2 media volumes, the top one( the default one) was never there before and it's pausing my music audio. I'm not even sure on how it got there, I don't have chromecast. Much help would be appreciated
Are you using poweramp as your media player? It seems you have it installed.
Poweramp uses DVC (Direct Volume Control) to give you better sound output, but it would also require its own set of controls, which would explain the second media volume control in your quick access panel.
Yes I am, but this never happened to me before. I use to have one media volume
Probably from either an Android update that permits apps to modify the quick settings panel, or an update to Poweramp that added that option. :thinking:
