Saw this phone seemingly too good to be true,
Specs:
Specs:
- Brand – Maze
- Model – Alpha X
- Alternative Name – MAZE X 4G Phablet
- Device Type – Android 4G Smartphone
- CPU – Octa-Core 4 x 2.5GHz ARM-A53 + 4 x 1.6GHz ARM-A53
- Chipset – MediaTek Helio P25 MT6757CD, 64-bit Processor
- GPU – ARM Mali-T880 MP2, 900MHz, 2-Cores
- Camera – 13MP+5MP Sony IMX258 Dual-LED Flash and AF Rear Camera | 5 Megapixel Front camera
- Memory – RAM- 6GB LPDDR4X, 1600MHz | ROM 64GB/128GB External Memory Support up to 256GB (Uses SIM 2 Slot)
- Display – Screen size 6.0 inches in-cell IPS, LCD Full HD (1080 x 2160 Pixels), 18:9 Aspect Ratio
- Battery – Non-Removable 4,000 mAh Lithium-Polymer
- SIM – Dual Hybrid SIM (Nano-SIM+ Nano-SIM/microSD), Dual Standby
- Sensors – Proximity Sensor, Accelerometer, Ambient Light, Compass, Fingerprint, Gyroscope, Hall Sensor
- Color – Black, White, Blue
- Operating System – Android 7.0 Nougat OS
- I/O Interface – 1 x Nano SIM Card Slot, 1 x Nano SIM Card Slot or microSD/TF Card Slot, Type-C USB Port, 3.5mm Audio Out Port, Power Button, Volume Button, Microphone, Speaker
- Dimensions – 155 mm x 75 mm x 8 mm
- Weight – 155 Grams (With Battery)
- More Features – Metal+Glass leather Body Design, Full Screen Border-Less Design, LTE Cat6 300 Mbps Download, 50 Mbps Upload, HSPA+(HSUPA 5.76 Mbps Upload, HSDPA 21 Mbps Download), Loudspeaker, Computer Sync, OTA Sync, GPS, OTG Support, Front Mounted Fingerprint Sensor Model, VoLTE Support, Tethering, Hotknot, Rounded Edges, 18:9 Screen Aspect Ratio, 5V/2A, 9V/2A, 12V/1.5A Charger Output Power, MediaTek Pump Express Fast Charging Technology
I'm not that big on 4K since I rarely use my phones for real photography, and I went to Versus.com to compare chipsets,
https://versus.com/en/mediatek-helio-p20-vs-qualcomm-snapdragon-808-msm8992
So with 6GB RAM, a bezelless 6.0 display, a 4000 mAh Li-Po battery, and an Octa-Core 4 x 2.5GHz CPU, for someone who is not an audiophile or photographer, this seems like the perfect phone for mid range me.
The slightly earlier model the Maze Alpha: (No "X")
Any thoughts?
