media safe/vault
ahthatguy
I have private videos and pictures I would like to keep away from wandering eyes and was wondering if there are any good apps for hiding them. Someone told me about an app called hideNseek that looked excellent but I can't find it on my market anymore. Can anyone help?
just bought and downloaded hidenseek, 50p/$0.99. works great should do the job for you. when installed the screen appears blank (for use as a "flash light") but infact if you press the menu button three times it will then ask you to imput a password.
hope this helps. check out the stick on applications for more useful apps
