according to samileo31 post on XDA forum:
The Meiigoo S8 has now been announced and along with that introduction comes confirmation of the full specs on offer with this smartphone. What is likely to be one of the main points to note is that this is a device that follows in the footsteps of a number of high profile 2017 smartphones by utilizing an 18:9 aspect ratio. The inclusion of this edge-to-edge design allows the Meiigoo S8 to make use of a smaller physical footprint compared to what would be encountered with a device adopting a more traditional bezel level. As a result, the Meiigoo S8 features a larger than usual 6.1-inch display, but within the body of a smartphone more often associated with a smaller display. A design aspect which not only looks to add a premium touch to this smartphone, but one which is also designed to offer a more comfortable holding experience.
The highlight features of the S8 are that it sports a 6.1-inch HD+ display with 18:9 aspect ratio which takes up 83% of the whole front panel and coated in dual-sided 3D curved glass. Spec wise, the S8 is equipped with a powerful MTK6750T octa-core processor clocked at 1.5GHz, 4GB RAM, 64GB of storage, expandable up to 256GB, dual rear cameras (13.0MP + 5.0MP combo), rear fingerprint scanner, 5.0MP front-facing shooter, USB TYPE-C, 3300mAh battery and Android 7.1 Nougat as the OS.
Look like Samsung S8
