Meizu MX6 Flyme 6.1.0.0a stuck with wrong firmware
jasonmx6
hi,
im in australia. ive ended up with this chinese version of flyme 6.1.0.0a on my phone. i am trying to install the international version 5.2.5.0g
but everytime i begin the firmware install, it just halts after 1 minute and returns to the current version like nothing had happened.
i have tried several flyme global firmwares to install, they all halt after 1 minute and fail. when i try to install the firmware from the "safe mode boot" it tells me the "firmware is corrupt" and i cannot proceed.
the only firmware i have actually been able to update to is flyme 6.7.6.13a beta
how do i get back to an international version!!!
p.s. ultimately, if its possible, i would like to remove flyme altogether and just run pure android.
regards
jason
Also might be worth you looking or enquiring on Meizu's own Flyme OS forum.
http://forum.flymeos.com/
In the past Meizu phones were pretty easy for swapping Chinese firmware for international versions, rooting, etc. Their current devices might be much more tricky however.
i have just spoken with meizu. my phone was originally based on flymeA -chinese version and it is not compatible with flymeG global version. there is no way i can change to global version, however there is hope that the next update will have this ability
