Help memory card issue
goingnatz
hi there, good day everyone....
i have a bit of a problem...
im using a samsung note 3 n9005, i bought a 64gb memory card, after a while, most of the pictures that are saved on my memory card is broken, videos cannot be played, says error cannot play video, and apps that are saved on it are grayed out, i already reformatted my memory card still the same, is there anything that i can do, should i buy new memory card, if i will to buy new memory card, what is the best brand out there, im confused between, samsung evo 64gb or samsung evo pro 64gb or transcend 64gb or sandisk 64gb? which one is the best, any thoughts? thanks....
yeah i think ur right, i bought it online, maybe its a knock off i can also feel it.... so which sd card brand is really good? cant decide,
Sandisk and Samsung are both good, I've used them no problems. Most important thing is where you purchase them, go to a reputable place like Best Buy, rather than online vendors or Ebay. I'm in China, where the fakes come from, so have to be especially careful.
ye
thanks a lot... i will be more carefull now just have to say goodbyes to those pictures away....
