I've not dropped the phone or anything but the menu and home now only work occassionaly its on 2.2, I've rebooted and taken the battery out but no luck, does this sound like a software or hardware issue, anyone else had the same ?
You probably flashed a pre alpha 2.2 rom which is way outdated. I suggest you to go to modaco and search for either swedish spring RLS5 which i'm running OR try FLB r11b, both these froyo roms are smooth and don't seem to have ANY problem.
