SANJISH KUMAR
Hi,
I have made a simple menu in android studio 3.2.1. The menu items shows ok in design view. However when i connect it to genymotion or youwave emulator it is invisible and when i click on the 3 dots in the action bar it says that unfortunately the app has stopped
The activity_main.xml file reads
The categegory.xml file reads as
<?xml version="1.0" encoding="utf-8"?>
<menu xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto">
xmlns:tools="http://schemas.android.com/tools"
<item
android:visible="true"
android:id="@+id/item1"
android:icon="@drawable/ic_launcher_foreground"
android:title="Item_Sales 1"
</item>
<item
android:id="@+id/item2"
android:icon="@drawable/ic_launcher_background"
android:title="Item_Sales 2"
</item>
<item
android:id="@+id/item3"
android:title="Item_Sales 3">
</item>
</menu>
and the MainActivity.java file reads as
package sun.rudraapp;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.support.v7.widget.Toolbar;
import android.view.Menu;
import android.view.MenuInflater;
import android.view.MenuItem;
import android.widget.Toast;
import java.util.zip.Inflater;
import static sun.rudraapp.R.menu.categegorymenuxml;
public class MainActivity extends AppCompatActivity {
* Initialize the contents of the Activity's standard options menu. You
* should place your menu items in to <var>menu</var>.
* <p>This is only called once, the first time the options menu is
* displayed. To update the menu every time it is displayed, see
* {@link #onPrepareOptionsMenu}.
* <p>The default implementation populates the menu with standard system
* menu items. These are placed in the {@link Menu#CATEGORY_SYSTEM} group so that
* they will be correctly ordered with application-defined menu items.
* Deriving classes should always call through to the base implementation.
* <p>You can safely hold on to <var>menu</var> (and any items created
* from it), making modifications to it as desired, until the next
* time onCreateOptionsMenu() is called.
* <p>When you add items to the menu, you can implement the Activity's
* {@link #onOptionsItemSelected} method to handle them there.
* @param menu The options menu in which you place your items.
* @return You must return true for the menu to be displayed;
* if you return false it will not be shown.
* @see #onPrepareOptionsMenu
* @see #onOptionsItemSelected
@override
public boolean onCreateOptionsMenu(Menu menu) {
super.onCreateOptionsMenu(menu);
MenuInflater inflater = getMenuInflater();
inflater.inflate(R.menu.categegorymenuxml, menu);
return true;
* This hook is called whenever an item in your options menu is selected.
* The default implementation simply returns false to have the normal
* processing happen (calling the item's Runnable or sending a message to
* its Handler as appropriate). You can use this method for any items
* for which you would like to do processing without those other
* facilities.
* <p>Derived classes should call through to the base class for it to
* perform the default menu handling.</p>
* @param item The menu item that was selected.
* @return boolean Return false to allow normal menu processing to
* proceed, true to consume it here.
* @see #onCreateOptionsMenu
@override
public boolean onOptionsItemSelected(MenuItem item) {
switch (item.getItemId()) {
case R.id.item1:
Toast.makeText(this, "Item 1 selected", Toast.LENGTH_LONG).show();
/* case R.id.subitem1:
Toast.makeText(this, "Sub Item 1 selected", Toast.LENGTH_SHORT).show();*/
Default:
return super.onOptionsItemSelected(item);
@override
setContentView(R.layout.activity_main);
/* setSupportActionBar(Toolbar);*/
/*android.support.v7.widget.Toolbar toolbar=findViewById ( R.id.toolbar );*/
/*setSupportActionBar ( toolbar );*/
and the androidmanifest.xml file reads as
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="sun.rudraapp"
<application
android:allowBackup="true"
android:icon="@Mipmap/ic_launcher"
android:label="@String/app_name"
android:roundIcon="@Mipmap/ic_launcher_round"
android:supportsRtl="true"
android:theme="@Style/AppTheme">
<activity android:name=".MainActivity">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
Please help
regards
Sanjish
Code:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="match_parent"
tools:context=".MainActivity">
</LinearLayout>
<item
</item>
<item
</item>
<item
</item>
</menu>
@override
return true;
* facilities.
@override
case R.id.item1:
Default:
@override
<application
<intent-filter>
</intent-filter>
</activity>
</application>
</manifest>
Please help
regards
Sanjish
