Mesh Module connection with Android phone
Robbyshawn
Is it possible to calculate the wireless data of mesh network by connecting the wireless modem device https://store.ncd.io/product/zigbee-coordinator-long-range-wireless-mesh-modem-with-usb-interface/ through the USB port which receives the data from the wireless transmitter and present the data according to mentioned requirement?
I never used any external wireless device to connect through smartphone and create the useful process so any kind of suggestion or sampled example to make it useful will be very helpful.
Hello as I have mentioned the link this wireless ZigBee module(as a receiver) with the standard protocol of 802.15. . connected via usb port of MOTO G4 android phone and I am trying read the signal strength of Zigbee transmitter which is sending the data to Zigbee receivers, so I need some suggestion which will help me check the signal strength of this module easily.
