Typically means that the message was not able to be delivered or sent..that happens while you tried in sending the message you had not network coverage in that precise instant..if you press the triangle you reefer to..it should give you the option to resend..
Xavier, thanks for the fast reply. Now I know what it means. I pressed the triangle and it just brought the message text back up. However I do have the option to phone this person so that's what I did. Very helpful info.
