hi guys...i'm using acer betouch e 400..trying to install yahoo messenger but it's failed to function smoothly...the application running well but when i sent any text beep sound will appear for a several time...need some advise...ty...i'm using android version 2.1
not like that sound bro...just sound tit..tit..tit...tit...already check the program
not such place to control or adjust the sound ...when i buzzzz.....another sound will appear in harder...
Ok I really don't understand what you are saying. What exactly is the sound? Does it come from the speaker? Are you sure its not just haptic feedback? WHen EXACTLY does it happen? When you are typing? When you send the message? When you receive one? What EXACT app are you using?
