Messenger not working
smashbox1
Has anyone else had any issues with messenger home page not loading?  I am also unable to receive messages in the app.  This issue only is a problem on my S8, which is brand new.  Unfortunately, it is a carry over issue from my S6, which I just swapped out this weekend.
The issue started on the S6 about a week ago, and after many uninstalls/reinstalls, a reboot, cache clearing, and now a new phone, nothing has resolved this.
The app works perfectly fine on my work iPhone.
I have sent 5 unanswered messages to facebook, and emails the app support, which has also gone with out a response.
Hi,
Hmm, just a theory, but if this problem is spanning phones then I guess the issue is either in the app or it's settings (which I assume that you copied across).
Given that you have certainly have checked the settings, I would try to load an older version of the app from http://www.apkmirror.com
Regards,
Eric.
Hi,
Regards,
Eric.
Thanks so much Eric.  I've tried that too, and they all have the exact same issue.  I've even uninstalled and have tried several versions, with no luck.  I checked and rechecked all of my settings against my iPhone (where the app works perfectly), and they are all the same.  This is maddening!!!  My iPhone is a work device and I don't use it often.
Appreciate the effort.
