Metamorph for dummies?
I rooted my droid and made a nandroid back up. Now I was looking into changing my theme to one i downloaded, it says it needs to be installed with Metamorph. I downloaded metamorph but I'm new to android and have been used to the blackberry setup of using the desktop manager for everything. So the instructions on how to use metamorph are pretty foreign sounding to me. Was wondering if anyone could help me out with some really simplified instructions or point me in the direction of a site that has some. Thanks in advance for any help!
Here are instructions on using it. Basically if you have a android phone that is not a Samsung Moment you will need a custom ROM. You have to make a folder on your sdcard called AndroidThemes. Any theme you download needs to go in that folder. When you run metamorph it will look in that folder for the theme and then you can apply it. All info is found on the link I posted.
My bad you did'nt list your device I thought you were working with a G1, go to theunlockr.com and click on android how to's and they should have instructions for you.
Glad to hear. I know how it is when you first start. I get everything there, and xda-developers, those are the best. If you don't already have your ADB setup, I'd advise getting it setup, it makes things easier and with some precedure don't have to shut your devices down. You can make backups and they're on your computer, you can make backups of your backup just in case your memery card gets wiped. Well' happy to have helped you out some, enjoy
