androidtim
Graphica Live Photo Maker
Welcome, often you need to take a picture of the screen Android device, and most of us have used the usual way by the sound and the power button at the same time or by the availability of this service applications, but do you ever think in capturing moving GIF image of your screen? You may want to explain via chat, for example, a particular person how the device implementation process on your phone, whereupon the action steps one after the other on your computer screen to take a picture with each phase.
There is a simple way allows you to move images successively recorded in the form of animated GIF image as video short and so either by camera or by taking a picture of the screen.
The method is based on the application of Graphica which provides you with the possibility of picking up comics to the screen Android phone.
Capture animated image by Android Camera:
The application interface is simple Graphica, after installing the application and open it will appear in front of you the following options:
If you want to take a series of images and save them in the form of animated picture Gif select the "fast moving picture" 'Quick live photo' where they will start the camera application and capture a short video clip of the later saved as an image animated Gif.
Taking moving picture screen Android phone:
Just take pictures of your screen by constant pressure for about two seconds on the sound and power button together cut button to the screen image is captured, collect images that you want to merge and then go to the following explanation:
Create GIF image from a set of images:
If you want to create an image screen animation Select "animated picture from the Photo Gallery" 'Galary live photo' application and will take you to the exhibition, where you will select the desired images and clicking on the following animated image created by then which will appear by clicking on the "Save Image" to save the image animation format Gif in Graphica folder on your device's memory.
VIA
Download the application Graphica:
VIA
