Root [MetroPCS/CDMA] calling with headphones :/
Zolo185
The factory headphones you get with the phone are great but when i make calls they stop working. Same thing is happening with other headphones with mics. Im on BB7 is it the rom ? becuz on Cm10.1 it would work also on aokp it also worked and of course on stock it worked. Can anyone help ? This is a feature i would love for every day use
Current bugs:
Unknown ICCID (4G still works)
Themes dont theme battery icon \___ seems these two bugs can be fixed by rebooting wipeing etc etc
Cant save pictures to external sdcard /
Back button is quirky
Bluetooth/wired headsets dont work
This is directly from the BB7 thread
and the reason why I personally never used the rom.
Stock debloated - deodexd. Mainly just waiting for drifta to get his #2 rom up and running so I could start using that.
But CM10.1 is a great rom and is what i used before if you prefer an aosp rom.
What does deodexd do? and i was on cm10.1 before going to bb7. I just love the being able to customize basically everything from the setting menu; Since carbon is pretty similer im thinking of switching to it but it still has some serious bugs
