Root [MetroPCS/CDMA] Cyanogenmod 11 MDN HELP!!!
chen369
I have a (MetroMobile) CDMA Galaxy S3 I recently changed my number and i got the new number but it still shows the old number on my phone.I cant put/receive calls but 4G/LTE works perfectly is there an app/method where I can change the CDMA's programmed MDN ??
revert back to stock, enable hidden menu's. get your msl and do a ##rtn# reset to reactive hands free activation. once you are reactivated go bakc to cm11.
not on cm. aosp roms dont support activation and other various things as its far too much work to reverse engineer them for each phone on each carrier and hope you can build a quasi working port. the only phones that have those features on aosp roms are nexus/gpe devices.
Ok im at stock did a ##786# reset now I have STOCK MDN and MIN
I Have my MDN but i dont have a MIN now what can i do ??
im not sure i follow. ##rtn# resets all the nv items to be redownloaded via hands free. assuming you didi it and your device hasnt been esn tampered than it will just grab the right info when it does a hands free.
I have to call *611 and ask for the MSID because it has not downloaded the NV Data.
##786# just did a cdma factory reset and removed my old number.
I have read a couple of forms and people had same problem is just MSID thats missing. My ESN has not been touched with.
It wired why it has not have updated its settings even after 29 hours since the new number was ported over
