Root [MetroPCS/CDMA] galaxy s3 - how to flash tmobile gsm radio?
AP2FTW
is there any way to change my cdma s3 into a gsm phone? someone has suggested its possible by flashing the tmobile gsm radio but i cant find any info on it...anyone have a link or info?
my phone gets check marks for all 3 but i dont see anywhere on that site how to flash a tmobile gsm radio into my cdma galaxy s3
I never said it did, I said check to see if it's possible before trying it.
But the real problem is that I spaced that T-Mobile is shutting down the CDMA network.
If you're trying to go from CDMA to GSM, pretty sure you can't.
First problem is that the CDMA G3 uses a UICC for LTE access - the GSM model has a what that service needs - an actual sim card.
Second problem is radio hardware.
So, I don't think that this is a flashing issue.
