Root [MetroPCS/CDMA] Just a general lte Rom question
jahunt78
With all these roms going unified do they only have 4g lte or is 3g as well cause I think I seen once or twice the 3g or 1x indicators flash for a second and then disappear and it'll have no connection until it finds 4g again instead of running 3g or 1x cause when I run the Mtr roms or non unified roms it'll change to the appropriate connections hopefully I explained that appropriately
As a general question, that's very specific. Each ROM does what it does, and that depends on what the person who put it together wanted it to do. It's like the general question "are cars red?"
Contact the Specific ROM's dev and you'll get your answer.
Slim has a general build. I posted in there what to change and the Dev said he will work on fixing it foot the next release
