Root [MetroPCS/CDMA] VALIDUS [5.1][OFFICIAL][d2lte]
I've been using it now for a while with no problems at all, I'm really digging this ROM its one of the most stable ROMs I've tried.
I suggest you wipe everything and format system before you install.
do you have to problem with mms. Someone posted a fix for 4.4 roms but it's not working anymore. It's so frustrating
Yeah I hear ya, I used the fix and it works for me.
What I do is take the MMS apk from the ROM extract it add the config file zip it back up .
I don't use the same MMS apk every time and it works for me
The only time I had a problem was when I tried to keep using the same MMS apk .
